ok, so I narrowed it down to two things: I know #6 isn't firing. I did the the idle drop test and 6 was the only one that didn't change.
I removed #6 plug and #5 plug and swapped them. did the idle drop test again and #6 worked on #5 plug. So I know it isn't the pulse or problem with wiring.
the question: can the injector be faulty or dead besides the possibility of it being clogged is there anything else the injector has that would prevent it from working?
