running lean with a ego heater cel
  • Goya20
    • 325
    the car been running lean changed spark plugs wires, distrubtor, rotor, and o2 sensor. I checked the fuel pump relay. Any suggestions?
  • vpilarrt
    • Jun 2006
    • 2096
    Vacuum leak
      As mentioned, intake leaks are a possibility, but there could be a fuel delivery problem, a bad ECT sensor, or even a bad DME.
      • Goya20
        • 325
        checked for the common vacuum leaks and nothing the ect sensor is the blue coolant sensor? I swapped dme's as well and same thing happened. I opened the original dme and found a bmp design chip in there. Im thinking of swapping the chip as well because i have another dinan for the same ecu number.
          • 34844
          how about the O2 heater relay? it's the same kind of relay as the FP. swap them around and see what happens.
          • Goya20
            • 325
            changed the chip and got a better idle around 800 rpm. so you saying swap the orange relay with the white relay near the driver side wheel?
            • Goya20
              • 325
              swapped relays and the same CEL
              • Goya20
                • 325
                i have some vr6 fuel injectors to see if the bogging is due to clogged injectors because i have 235k on the motor
                • Goya20
                  • 325
                  will they fit?
