HELP!!! Temp goes up when a/c is on
  • rstimpreza
    • Sep 2011
    • 216
    Hi all, bare with me on this. this is my second e30 but this time its an m42. My problem with the car right now is when i turn the a/c on. the temp needle goes up. as i adjust the a/c higher the temp needle will even go up(hotter). another thing is when i push up/down on my window button the the needle on both gas and temp gauges flickers. Anyone can help me on this? Thanks in advance.
  • blunttech
    • 12850
    Originally posted by rstimpreza
    Hi all, bare with me on this on this is my second e30 but this time its an m42. My problem with the car right now is when i turn the a/c on. the temp needle goes up. as i adjust the a/c higher the temp needle will even go up(hotter). another thing is when i push up/down on my window button the the needle on both gas and temp gauges flickers. Anyone can help me on this? Thanks in advance.
    clean your grounds. Its good to have an infra red thermometer too to actually see what its running at. Sounds like a dirty ground though
    sales@blunttech.com
    www.blunttech.com
    Like us on Facebook
    • ///digitalme
      • Dec 2009
      • 2088
      i have the same problem with the gas and temp flickering when i push the windows down...i was told it has to do with the wiring/grounds....it all started when i swapped another engine....so i suggest cleaning your ground cables making sure theres no moisture on them..as for the temp i have no clue but check your temp sensors? radiator sensor?
      • rstimpreza
        • Sep 2011
        • 216
        Thanks for the advice but how many wiring/ground connections does m42 have i tried looking and cant find it. can anyone point me to the right direction. thanks
        • ///digitalme
          • Dec 2009
          • 2088
          by the engine mounts...the the firewall...um.....
          • rstimpreza
            • Sep 2011
            • 216
            anyone here know about temp rising while raising the ac high
            • russhixmo
              • Jun 2011
              • 336
              I'm Gunna say Check your grounds as well.
              • ///digitalme
                • Dec 2009
                • 2088
                as for the overheating...make sure your fan clutch is engaging....id say its your fan clutch
                • AndrewBird
                  The Mad Scientist
                  • 11898
                  Pretty sure Blunt was talking about the grounds on the gauges themselves on the backside of the cluster.
                  • rstimpreza
                    • Sep 2011
                    • 216
                    anyone here had this issues before i need more advice i checked the gauges and still the same.
