can someone explain the factory crank case ventilation system to me?
my current setup has a pipe from the cam cover to a catch can, then a line from the catch can to a inlet on the throttle body.
my motor has developed a fairly serious oil leak(s) in the last 2000km since the simplified crank case system was installed. i am wondering if there is a build of pressure in crank and its pushed a seal?
prior to the revised setup it hasn't used a drop.
