I have looked at all my local fastener stores, online, and even Home Depot and cannot find (2) M10 - 1.25 & (2) M12 1.50 lock nuts so I can reinstall my front suspension. Anyone have a clue? It was to late for me to call BavAuto. But I looked throught their catalog and only found new control arm and tie rods.
Need Lock nuts for tie rod and cont. arm
They're a pretty uncommon thread-pitch for the size of the nut, hence why you're having a hard time locating some. A friend here just picked some up at the dealer locally, so maybe they're available down there.Originally posted by Grueliusand i do not know what bugg brakes are.Comment
tie rod lock nuts are m10x1 not 1.25 i just replaced one of mine. 07 12 9 922 436 this is the dealer part number from the ETK. try some auto stores or the dealer.
Also there are two different lock nuts on the control arm m14x1.5 and the m12x1.5
m14 31 12 1 095 420
m12 32 21 095 267
hope this helps,
StevenComment
Thanks, I would have beat them with a softer hammer if I knew they were this hard to find.Originally posted by mcgrathtie rod lock nuts are m10x1 not 1.25 i just replaced one of mine. 07 12 9 922 436 this is the dealer part number from the ETK. try some auto stores or the dealer.
m14 31 12 1 095 420
m12 32 21 095 267
hope this helps,
StevenComment
my lemford ties came with new nuts but the lemford CA's didnt come with nuts. Thanks for the PT # for those, but first I need to remove that inner ball joint, im thinking about using a hacksaw to get that fucker off.Comment
Thanks, its a work in progress.Originally posted by nefarious7907I never even noticed the turbo in the sig pic, very nice
As far as using the bolts again, They dont work the same after you beat them with a metal hammer to ge the tie-rod and control arm. I tried to save them but a plastic mattel wouldn't cut it. Plus they are 20 yr old nylon nuts. Not the best idea for a "track" car.Comment
