No heat
  • Zinno_e30
    • Jul 2010
    • 553
    No heat
    The fan does not work in any position (1-4), regardless if it is on heat/AC. I am assuming it is the blower motor - is this the culprit?
  • Ceeker
    • Sep 2009
    • 2821
    blower fan resistor -responsible for fan speed located below the blower motor. slip your hand under the motor and pull up-slides out. install new one about 20-30 bucks - make sure it is a 4 speed resistor and not a 3.
    • Zinno_e30
      • Jul 2010
      • 553
      I've read that the resistor is the fix only if the fan works in position 4, however, my fan does not work in any position. Is it still the resistor?
      • Wh33lhop
        • 11705
        A dead resistor will still allow the fan to operate at full speed since that is just a short to power.
        I am curious, are your AC/recirc buttons lighting up or are they dead too? Have you checked the fuse?
        paint sucks
          Since the fan doesn't work at any speed, it won't be the resistor. A blown fuse, bad fan switch, bad unloader relay, or burned out fan motor are what you should be looking for.
          • Zinno_e30
            • Jul 2010
            • 553
            It was a bad fuse - I appreciate the help! I ended up replacing several other fuses and got my interior lights working again :)
            The heat finally works, however the fan makes a loud noise in positions 3 and 4 - could it be the blower fan?
            • b*saint
              • 3794
              Mine was like this. I took it out, cleaned the brushes, sprayed the bitch out with brake cleaner, reassembled, replaced the 30A fuse and its been working fine.
              Ma che cazzo state dicendo? :|
              • StereoInstaller1
                GAS
                • 22679
                Yes, it is bad. The extra stress of bad bearings or just filth in the bushings is why the fuse blew.
                Thus:
                maybe do a little lubrication with a drop or two of sewing machine oil too.
                Closing SOON!
                Thanks for 10 years of fun!
                • b*saint
                  • 3794
                  I thought of that but I didn't want to use anything conductive near the brushes.
