Help Diagnose this Noise
  • Eurospec
    • 2611
    On startup every now and then, the engine makes an odd noise. It flippin sounds like a diesel. The noise usually persists until I turn the engine off, however there have been times where it has disappeard. Check it out: Audio File
    What could the problem be?
  • Stu Mc
    • 4083
    If not the timing chain tensioner, my next guess would be a worn guide/rail. When mine was worn and about the break (the rail), my M42 sounded just like yours.
    • AdamF 88iS
      • 2051
      Is your oil full?
      Adam Fogg- '88 M3
      Common sense- It's the new 'gifted'
      • Eurospec
        • 2611
        Originally posted by AdamF 88iS
        Is your oil full?
        Just checked it yesterday and its at a normal level.
        Again, this doesn't occur on every single startup.
        • Stu Mc
          • 4083
          on cold starts? hot starts?
          • Eurospec
            • 2611
            Cold
            • Stu Mc
              • 4083
              probably chain tensioner
              • E30Driv3R
                • May 2004
                • 1169
                Ive had the same problem and i think it is the tensioner, atleast for me try it, but always check the oil if that noise persists, that was another problem of mine .
                Dan Zickel
                1995 M3, 1991 318iS, 1987 325iS
                • Jon '92 325ic
                  • 172
                  Have you replaced your timing belt recently?
                  • Eurospec
                    • 2611
                    Not sure if the chain was ever replaced. I should get it checked out.
                    • The Fast One!
                      • Jul 2005
                      • 856
                      DUDE DON'T drive your car anymore!!!!!!!!
                      you could kill someone that is standing close by whenever your driving or just standing around!
                      you guys don't know what that is.
                      it's your muffler bearing man!!!!
                      wow thats an expensive fix too it's cost me like 400 dollars to fix it......
                      Mike Fritz
                      • hamann318is
                        • 3382
                        I'm willing to bet it's the tensioner too. Mine sounded just like that when I fixed the head and got a new tensioner before the tensioner filled with oil.
                        The BMW 318 is back. With a vengeance.
                        • RobertK
                          Kicked cancer's ASS.
                          • Jun 2005
                          • 5864
                          Sounds just like my roomates old bimmer.. it too was a timing chain tensioner.
                          • Eurospec
                            • 2611
                            Guess I'm not the only one. Thanks for the input!
                            • bddog
                              • 351
                              Adjust those valves! Sounds like the propeller in the water pump is grinding metal. That bearing or maybe the one in the power steering or the alternator could be shot.
                              Use a short stick to your ear to locate the noise.Then you will know. Be carefull!
