Originally posted by Jon '92 325ic
Help Diagnose this Noise
Adjust the valves?Originally posted by bddogAdjust those valves! Sounds like the propeller in the water pump is grinding metal. That bearing or maybe the one in the power steering or the alternator could be shot.
Use a short stick to your ear to locate the noise.Then you will know. Be carefull!
Just a question...
Hydraulic valve lifters don't need to be adjusted. Yet, two people have mentioned this. Curious.
Can someone post up that sound file again. I'd like to hear it and compare it to my new 318is and see if we're talking chain / chain tensioner.
Thanks!
-PrinceComment
not only that but the hydrolic lifters cannot be adjusted... if it is indeed the lifters they are worn out and need replacing. run a detergent in the oil before your next change, i had a ticking noise on start up, ran the cleaner and it went away. the hydrolic lifters have little pumps i guess you could call them and if they are clogged you will get a ticking noise or if the dome ontop of the lifter is worn you will also get a ticking noise.Originally posted by PrinceE30Just a question...
Thanks!
-Prince
PS: the sound file is down.Comment
