Best manual tranny fluid? Mobil one or Redline?
  • Waynegro
    • Aug 2005
    • 160
    Greetings,
    I recently had my tranny fluid chaged with some castrol fluid and my tranny has a very hard time getting into gear when it is cold. I want to change the fluid this weekend. So what should I get, Mobil one (which weight is best?) or Redline MTL? I have a 5sp 325is. It seems like most of the board members use Redline MTL, is that the best to go with? Or does Mobil one offer a similar product? What do the dealerships use?
  • James Crivellone
    Head Janitor
    • 6304
    I use Redline MTL, once the fluid warms up it shifts great with it.
    • AdamF 88iS
      • 2051
      Redline LT Shockproof.
      Adam Fogg- '88 M3
      Common sense- It's the new 'gifted'
      • demlotcrew
        • May 2004
        • 297
        I use this race spec stuff, and its the summer here in the UK! when cold i cant get it into gear at all without rev matching! I have found that any other oil when gets warm makes the gear changes stiffer but this oil makes them easier, the gears are "sucked" in if you will.
        SAE 75w90 or so should be a good start.
        Andrew
        Andrew AT E30zone.co.uk | H23-is | S14
        • bmw_e30
          • 442
          Do you use it for both your tranny and your diff?
          • Digitalwave
            is a poseur
            • 6292
            I use Redline MTL in my tranny and Redline 75w90 with LSD additive in my diff, both are great. The diff fluid quieted up my 4.10 LSD a lot.
            RISING EDGE
            • e30sd
              Fistee
              • Jan 2004
              • 5517
              be a hero, go with kendall 80w90.
              • AdamF 88iS
                • 2051
                It's too light for the diff. I use 75-90 in there.
                Redline specifically says NOT to run 75-90 in the tranny, says it right on the bottle. It's too heavy.
                Adam Fogg- '88 M3
                • robweenerpi
                  • 46
                  I too prefer thicker oil. Just be careful on the first few shifts until you get a little bit of heat going.
