I successfully completed the transmission swap this past weekend and upon following the instructions on how to wire up the manual tranny to the auto wiring harness it working after a second try. The first time I originally had the wires from the reverse switch backwards (checked fuses - non are blown) after I switched them around the car started right up.
I did not, however, find the "red/white" wire referenced to in the 5 speed swap thread Marvin created. All I have left was a reddish brown wire.
The problem I have now is that NONE of the power windows work but the sun roof still does. Everything else in the car is fine. Is there a wire I missed or something I should have done with that reddish brown wire?
