cone filter adapter
  • natorious
    • 672
    cone filter adapter
    What is the best option for a cone filter intake / af adapter that isnt 140 bucks like the bavauto one
    • 34844
    first ask yourself the question, why am I doing a cone filter? because if the answer is for increased horsepower, you're barking up the wrong tree. You're more likely to lose horespower from a cone filter on an E30.
    otherwise, check ebay for cheap adapter kits.
    • natorious
      • 672
      one reason - sound
      do you get much intake roar with just the plates?
      i am vey aware that it wont help much at all and in fact may loose power when in traffic... i will be fabricating a heat sheild tho
        • 34844
        well if you use a heatsheild you will be okay. Sound is pretty much the only valid answer to that question, other than maybe ditching the factory AFM system altogether. :)
        what do you mean by plates?
        • aaron_silva
          • 1785
          Sound is hardly noticable. The lenght the air has to go through is not long enough to resonate. If you had a long tube that stuck the filter somewhere else other that in front of the AFM, then you might get a louder intake noise.
          • rs4pro3
            • 5808
            The factory BMW Adapter is the best one, just buy one of an 83-85 E30 or E28 with the M20 engine in it. Before 86 BMW used a round inlet airbox for the AFM unlike the newer style where the AFM bolts right to the airbox. You can use one of these adapters and go buy a K&N filter at the local autoparts store and Eric Lukas's Heat shield and one be out maybe $60-$70.
            If you want one of the factory adaptors I might have one I'll sell. PM me if intersted.
            85 325e 2.7 ITB'd stroker
            • bimmerphile
              • 3495
              I assume he means the flat plate-like air filter...
              • Rob
                • 8166
                or adaptor plate
                BEERTECH
                • Mystikal
                  Wheel Fitment Expert
                  • 9602
                  Mine is pretty damn sexy-loud. Scared the shit outta me the first time I went WOT. :D
