12.67 volts, good or bad?
  • Bene
    • Feb 2011
    • 358
    after driving around I stopped by autozone to check the battery, it was at 12.67 and the meter said to replace it. I was under the impression that over 12v is fine.
    sometimes it just doesn't want to start, I'm starting to lean toward the starter.
  • LJK
    • 38
    What was used to test it? A midtronics tester? If it was, those test the capacitance of the battery.
    • Bene
      • Feb 2011
      • 358
      I have no idea, I just went to autozone and asked to have the battery tested. The readout said it had 100% charge, 12.67v and the word replace (or something along those lines).
      • SpecM
        • Oct 2005
        • 4531
        voltage has nothing to do with it
        a Midtronics tester (like Advance has, not sure about AutoZone) also tests the CCA (cold cranking amps), which measures the battery's ability to produce current, aka Amps. Any battery that produces less than 85% of its origional CCA rating should be replaced.
        1989 cirrisblau-metallic 325i
        • AndrewBird
          The Mad Scientist
          • 11898
          Was it 12.67 without the engine running? If so, I would think that should be fine.
          But like SpecM said, it's not just about voltage. I could make a potato battery that would read 12v, but it sure as hell won't start your car.
          • e30s50dan
            • Nov 2008
            • 2076
            Yea dude...what cold cranking amps does the battery say...and what year is the battery...if it's 5+ years,it's probably ready for a new one...I seem to go thru batteries a lot
            NASA
            BMWCCA member
            PCA member 25yrs
            1991 318IS slick top
            1997 M3 sedan
            2001 325CI DD
            “whoever turns the wheel the least, wins"
            • TobyB
              • 5296
              Replace it.
              It's shot.
              Or your charging system's not so hot.
              Voltage is a very good indicator of the state
              of a lead- acid system. (no, it doesn't work on your model airplane, nor your iPoop)
              If you drove the car to CluelessZone, it should be pretty much
              fully charged, and with no load, read well over 13v. Running, 13.7 or so.
              If the battery has a weak cell, it'll read low. If the alternator's not fully functioning
              it'll read low. If you have a bad connection somewhere (and there are a LOT of somewheres)
              it'll read low.
              12.6 might be fully charged for a battery that's been at rest for over 24 hours, but
              one in a car that's still warm should be in the low to mid 13's.
              Really.
              t
              • Bene
                • Feb 2011
                • 358
                alright, thanks for the input.
