Got my Euro Elipsoids
  • James Crivellone
    Head Janitor
    • 6305
    However I cannot find the part number for the connectors to use for my car.
    I currently have sealed beams, so I need to splice the harness obviously. Also what fuse ratings do I need to use higher wattage bulbs :)
    thanks dudes :)
  • Rob
    • 8166
    that may or may not help....
    BEERTECH
    • Spaz
      Crazy Canuck
      • 2276
      if you have sealed beams you will not need connectors i believe because the h4/h3 bulbs use the same connectors. i don't know if you need to install a higher fuse though. you can ask someone that has installed them. if i find out i'll let you know.
      Cam .W '91 325is
      Spaz's 1991 Alpine White???? S52 Build Thread...
      • James Crivellone
        Head Janitor
        • 6305
        the euro's use H1's, so I do need to splice the connectors
        • Spaz
          Crazy Canuck
          • 2276
          the h1's are the highbeams though right???
          Cam .W '91 325is
          • James Crivellone
            Head Janitor
            • 6305
            low and high IIRC
            • Ryan Stewart
              I Love Miatas
              • 8978
              both low and high. You can still build the plugs using the parts and the waterproof rear covers listed on e30m3therealm3.com but you will need to get the plug part # for the low beam.
              Then do the relay mod.
              Im now E30less.
              • bimmerphile
                • 3495
                Connectors? bah. I soldered and sealed everything with silicone.
                Those lights will see HIDs anyway, so those connecters will be cut/modified.
                • James Crivellone
                  Head Janitor
                  • 6305
                  I like to be neat :p
                    • 34847
                    my ellips should be here wednesday. I'm not putting them in though until I get my urethane covers from bavauto, there's too many gravel trucks around here.
                    • bimmerphile
                      • 3495
                      the warming step is very important.
                      • M42Technik
                        • 9781
                        How much those run apiece?
                        James, PM e304lfye on the part #'s needed, he helped me out when I got mine a while back, he should be able to give you the #'s since the one on that link (e30m3therealm3) are euro connectors and cost alot more than others you can use. I went from sealed beams to euro ellipsoids, and once you get it done you'll flip at how damn good they are.
                        Reminiscing...
                        • Ryan Stewart
                          I Love Miatas
                          • 8978
                          Just for info: My connectors didnt have to be modified.
                          Im now E30less.
                          • kencopperwheat
                            King of Kegstands
                            • 14396
                            Sorry to semi-hijack this thread, but I just have to say how cool Ryan's new signature is! I dig it man... 8)
                            Originally posted by Gruelius
                            • Ryan Stewart
                              I Love Miatas
                              • 8978
                              Thanks!
                              Props to E30bokes on Bimmerforums for that though, I lack artistic talent. :oops:
                              Im now E30less.
