Washer Fluid reservoir tank removal
  • OttoBob
    • Dec 2010
    • 88
    I misplaced my Bentley manual...I need to remove my washer fluid reservoir on my 1989 325iX. It is located at the firewall on the passenger side. There is only one obvious 10mm screw that I removed, and the reservoir is still firmly in place. I need to remove the reservoir to deal with some small rust. Some friendly help would be appreciated. Thanks.
  • Sagaris
    • Sep 2009
    • 2243
    Slide the tank upward, following the angle of the wheel-well and it will pop right out. There is a bracket that it sits in, exactly like the bottom of the coolant res. (if you have a late model 325i)
      • 34839
      yeah, I think there's a little clip or something that holds it in on the other end, you just need to pull.
