Clicking Window
  • Zinno_e30
    • Jul 2010
    • 553
    Clicking Window
    My passenger side window clicks when it reaches the top. Other than this, it functions normally. It seems that it does not seal properly because you can hear wind at high speeds. Is this due to a faulty window regulator?
  • kvvikdrawmcgraw
    • 71
    Mine does the same thing, though mine is much more drastic, theres about a 1/4" gap. Have a feeling its just getting caught up on something but haven't taken the time to look into it.
    • long tall eta
      • Jul 2010
      • 1536
      my drivers window does it when it goes down. functions fine till she reaches the bottom then does the clicking thing. it also stays above the door about 1/4 inch. been doing it for 3 years.
      • Zinno_e30
        • Jul 2010
        • 553
        This is extremely annoying - especially to my passengers when I am driving at high speeds. Anyone know what could be causing this? I've read online that the clicking noise means the regulator is failing. Could the window just be off the track or misaligned?
        • bimmernut333
          • Feb 2012
          • 97
          My guess is it's one of a few possibilities.. A, the bracket that holds the motor to the regulator loosened up a lil allowing it to slip. B, the motors gear is stripped. C, the regulator itself is gummed up and isn't moving freely and needs to be cleaned and regreased. Or possibly an alignment issue with the glass. Just my $0.02
          • slippery
            • Nov 2011
            • 373
            My passenger side window has the exact same problem. I just picked up a new motor this weekend, will let you know if it solves the problem.
            BTW, I believe early/late model regulators are different; make sure you order the correct one.
            J
            • Zinno_e30
              • Jul 2010
              • 553
              J
              Did you ever get around to figuring out what the culprit was?
              • dashboardmonkey
                FUCK YOUR WAFFLES
                • Jun 2008
                • 6158
                window regulator is wore out
                -Andy
                • slippery
                  • Nov 2011
                  • 373
                  Sorry, not yet. I will this weekend and update the thread.
                  J
                  • Zinno_e30
                    • Jul 2010
                    • 553
                    bump
