Water in rear floor
  • Apex381
    • Mar 2004
    • 740
    Water in rear floor
    Its been raining for almost a week now, I go out to my car and noticed that the area behind my passenger seat is soaked. I pulled up my floormat there and it looks like its been going on for a while. Where is this water coming from? I thought I remembered hearing about this before, but I couldnt find it using search.
    1987 325is - sold
    2001 330i - New DD
  • asubimmer
    • 6482
    dang bo... thats crazy!!
    what about your rear window seals?
    • Apex381
      • Mar 2004
      • 740
      do you live on here now? No the rear windows are fine
      1987 325is - sold
      2001 330i - New DD
      • kencopperwheat
        King of Kegstands
        • 14396
        Pull up the carpet and see if the 'plug' is not glued down.
        Originally posted by Gruelius
        • Apex381
          • Mar 2004
          • 740
          excuse my ignorance, but "plug"?
          1987 325is - sold
          2001 330i - New DD
          • Nathan
            • Apr 2004
            • 671
            I had this exact same problem. Turned out to be my tailight seals. They were bad, very bad. So basically any water in the trunk will eventually make its way into the passenger side rear foot area. Also check to make sure your sunroof drains are not clogged. This is also a common problem.
            Good Luck!
            PNW E30 CREW ///
            • kencopperwheat
              King of Kegstands
              • 14396
              Lift up your carpet and look. There is a hole about the size of a CD that another metal 'plug' fits into. Just lift up the carpet and look.
              • Apex381
                • Mar 2004
                • 740
                where are the sunroof drains?
                1987 325is - sold
                2001 330i - New DD
                • asubimmer
                  • 6482
                  ha i told you it was prob from the trunk beau
                  • kencopperwheat
                    King of Kegstands
                    • 14396
                    Rocker panel. There are three weep holes. Cram a flat-head in there and make sure they're all open. If you can, use a compressor to blow them out.
                    • asubimmer
                      • 6482
                      oh yeah i almost forgot what a sunroof is!!
                      • Digitalwave
                        is a poseur
                        • 6299
                        Wow, you have added absolutely nothing to this thread.
                        RISING EDGE
                        • Beej '86 325es
                          • 2639
                          Another spot to check is the elephant trunk looking rubber drain under the hood. It is located on upper part of the firewall, on the passenger side. It basically drains water that goes down the vents by the windshield wipers. Sometimes it can get clogged, or even a super heavy rain can cause it to back up. But if that clogs, then the front footwell would be wet too.
                          ...just another spot to be aware of.
                          -Brandon
                          '86 325es S50
                          '12 VW GTI Autobahn DSG
                          '03 540i M-Sport (sold)
                          '08 Jeep SRT-8 (sold)
                          For sale:
                          S50 TMS chip for Schricks
                          • screamingbmwe30
                            • Jan 2005
                            • 415
                            "oh yeah i almost forgot what a sunroof is!! "
                            mr salvage title 318is,
                            no one cares that you dont have a sunroof. stop bragging about it. its annoying.
                            you are forever a story making dumbass,
                            screamingbmwe30
                            • asubimmer
                              • 6482
                              oh yeah i guess you are right, since i was the first one to post and i know that beau has the pop out windows and the seal might be screwed. also what about the trunk???? digitalwave you can stfu and go back to your little corner.
                              and screamingbmwe30 you are just mad cause you don't know crap about hid's and i made you look like a fag
