windshield lock trim help
  • bmwstephen
    • 2463
    so the front windshield is the last thing i need to reinstall on my freshly painted car. before I ruin a good lock trim, I want to understand how you should start the installation?
    Do I position the end of the trim right on the passenger windshield wiper pivot or do I start a little before it? I don't want the final piece that is the lock strip connecting the 2 ends of the trim to be off-center
  • Garageaholic
    Freestyle Fabricator
    • Dec 2005
    • 5204
    Start at like 1/2" off center. For some reason when I've installed these things, I end up with a larger separation than the lock strip can cover. Maybe cause I compress it as I install it somehow.
    Bavauto sells a lockstrip tool for $8 that helps a bit. I also suggest using plastic or nylon pry kit so you don't knick the paint.
    Lastly, I use a dish wash soapy water combination spray bottle and keep the strip saturated the whole time.
    Recent Rebranding!!
    E30 SM62/S62
    E30 M60 V8
    E30 M30 Big 6!
    Instagram.com/garageaholic
    Youtube.com/garageaholic
    • bmwstephen
      • 2463
      ahh thanks! just wanted to be sure I don't start from the center marking
      • long tall eta
        • Jul 2010
        • 1536
        i bought the tool and it does make the job easier. you would be wise to wait for a warm day or crank the heat in the garage as they are much more pliable when warm. and +1 on the dish detergent.
        • 85e325
          • May 2011
          • 551
          Im trying to reinstall my excisting lock trim after having to pull my windshield in order to replace my sunroof regulator. Anyway Im dealing with the original one piece molded trim and I was wondering if anyone had any ideas or experience with this
          Justin Angelli
          1985 325e Gazellenbiege
