Disabling Wiper Fluid Sensor
  • Zinno_e30
    • Jul 2010
    • 553
    Is there anyway to disable the sensor so that my wiper fluid light indicator does not appear? I deleted to washer reservoir (never use it) and the indicator light annoys the hell out of me.
  • csermonet47
    • Jul 2009
    • 937
    Connect the two wires from the switch. It will be the blue/purple wire and the brown one. It completes the circuit and turns the light off.
    Are Three Vee
    Dad Spec
    • dnguyen1963
      • Nov 2011
      • 2651
      or just take out the bulb.
      • smooth
        • Apr 2005
        • 1940
        my fuse pops when the circuit is completed and I don't know what to check
        Das ist nicht nur nicht richtig, es ist nicht einmal falsch!
        • csermonet47
          • Jul 2009
          • 937
          Make sure you aren't connecting the washer fluid pump wire to something else seeing as washer fluid pump is hot. There are a good bit of wires between the pump and switch. The colors might be different between the years. Mine is a 1991.
          Are Three Vee
          Dad Spec
          • smooth
            • Apr 2005
            • 1940
            Well I am just connecting the fluid sensor so I'm not doing the wrong wires for certain. I also checked the sensor in another member's car to verify it works properly and it does. There's a short somewhere apparently but I don't understand where I should be looking.
            • Zinno_e30
              • Jul 2010
              • 553
              Reviving this from the dead - can anyone verify this? I have an 87.
