WTF Does this button do!?!
  • RobertK
    Kicked cancer's ASS.
    • Jun 2005
    • 5864
    On the 4 door autos what does the stupid square button do right above the driver side windows switch. I've been through the manual three times and it doesn't mention a damn thing.
  • asubimmer
    • 6482
    i think its the window circuit breaker (ie to turn off your windows) Sometimes its hard to make the button come up. You have to push hard in the middle of it.
    • RobertK
      • Jun 2005
      • 5864
      The windows circuit breaker is the black/red button in the dash above the radio and is about the same size as the fog light switch.
      • asubimmer
        • 6482
        well just a guess. thats where mine is (91' 318is) Oh well
        do you have a pic of this other button?
        • Jarvis
          • 2132
          I think one is for all windows and one is for strictly the back windows. aka child safety feature.
          • asubimmer
            • 6482
            ahhh that would make since then. What does the one on by the radio do? I have a coupe so it only does the front windows ;)
            • RobertK
              • Jun 2005
              • 5864
              If that's true I could just splice the wires that go to the button together and use the switch to enable/disable my cruise control since I've swapped from an automatic right?
              • rs4pro3
                • 5808
                Don't do it, are you serisoley going to remember to press a button everytime youy hit the brakes, or the clutch pedal? all you need is a bracket and switch, the wiring is already in place.
                85 325e 2.7 ITB'd stroker
                • RobertK
                  • Jun 2005
                  • 5864
                  What exactly do you mean?
                  I would think breaking would still work to turn the CC off.
                  • rs4pro3
                    • 5808
                    Yes, but if you ever shift, you will overev the engine. You either have to press the switch or brake pedal everysingle time before you press the clutch pedal. Like I said the wiring is there for the clutch switch, from the factory on auto cars it has a plug looping the two wires together, the bracket bolts right to the side of the pedal box, super simple job. I wouldn't do it anyother way, as if you encounter a panic situation where you have to downshift quickly to get out of someones way.
                    • Rob
                      • 8166
                      ejector seat
                      BEERTECH
                      • george graves
                        • 20003
                        Originally posted by Matt-B
                        • RobertK
                          • Jun 2005
                          • 5864
                          I was thinking more along the lines of a button to activate my
                          NAWWWWWZ!
