F***ING fuel pump
  • jrobie79
    • Mar 2006
    • 2526
    F***ING fuel pump
    I just replaced my fuel pump...and it fixed the problems I was having accelerating at WOT as I described in a previous thread...
    New problem, it appears to be the power connector at the fuel pump. It is a 2 prong female end harness. Even with the locking tab on, if I tap the connector or move it even a little bit, the pumping noise changes and the car sputters until I keep downward pressure on it; then it stays running. If i tug on a lil more, the pump shuts off and the car a few seconds later. I currently have a piece of foam wedged in there to keep it pressed down but that's not gonna fly permanently.
    Where can I get this connector? Its such a pain in the ass to use realoem for electrical connectors, any advice?
    1991 318i ---- 308K - retired
  • io_RobbieRodgers
    • Nov 2011
    • 57
    There are plenty of (easy) ways to splice wires, it won't look pretty, but how often does anyone see your fuel pump?
    Reformed E34 addict. 1993 525i/5 - 1995 525i/5 - 1991 318i/C
    • jrobie79
      • Mar 2006
      • 2526
      i know, I did that for my speed sensor, but I was hoping to keep this one more factory
        Get the connector from your dealer or scarf one off a car in a salvage yard.
