Loose cruise control lever?
  • Joey Link
    drunkest guy at Oktoberfest!
    • Nov 2004
    • 1176
    I searched a few boards and couldn't find anything about this. My cruise control works but the lever has so much play that when I press it up to resume it hits my wiper lever. How can I tighten this up as it's supposed to be stock?
  • parkerbink
    • Jun 2004
    • 10138
    Sounds broken to me. My directional did that right before it broke off completely.
    • DarkWing6
      • Apr 2004
      • 7144
      At least it works. :D
      Mine feels fine, but doesn't work.
      • Joey Link
        • Nov 2004
        • 1176
        Lol. I guess I'll have to take the column apart and see what's goin on.
        • fporro
          • 1860
          there's one 1 screw holding the C/C switch to steering column.
          as per non function C/C system, did you check the clutch pedal switch (if applicable) they do come loose too.
          • DarkWing6
            • Apr 2004
            • 7144
            Where is that?
            • Joey Link
              • Nov 2004
              • 1176
              So maybe I just need to tighten that screw, eh?
              • Addissimo
                • Mar 2004
                • 1820
                Originally posted by DarkWing6
                Where is that?
                uhhhh......
                seriously?
                its next to your clutch pedal swing arm below the steering column.
                -Addis
                Doing something M50 related? -> http://www.addissimo.com
                On Myspace? ->http://groups.myspace.com/r3vlimited
                BF2142 SN = BillyGoose
                • fporro
                  • 1860
                  yeap, seen it many times.
                  only remove the steering wheel with a 22mm socket or a 4 way lug tool, then you'll have access to it.
                  • Beej '86 325es
                    • 2639
                    Mine started getting loose a few years ago too. Like fporro said, take off the steering wheel, pop open the steering column cover and you can just tighten the screw(s). I haven't had a problem since.
                    -Brandon
                    '86 325es S50
                    '12 VW GTI Autobahn DSG
                    '03 540i M-Sport (sold)
                    '08 Jeep SRT-8 (sold)
                    For sale:
                    S50 TMS chip for Schricks
                    • Joey Link
                      • Nov 2004
                      • 1176
                      Shit you have you pull the steering wheel?
                      • Beej '86 325es
                        • 2639
                        It's easier than it sounds, trust me.......unless you have an airbag.
                        -Brandon
                        '86 325es S50
                        For sale:
                        • golde30
                          • 11464
                          when i bought my e30 the CC stalk was dangling around, 1. i took off the steering wheel(2min) 2. then took off the steering column panels there(another 4min) 3. then saw the screw sitting in the panel, put it back on(1min). repeat steps 1 and 2.......soo simple.
                          IG: @Baye30
