Super eta fuel pump vs standard eta fuel pump
  • modifiede30
    • 1208
    Anyone know the difference, are they compatible, etc. I'm having problems with an engine transplant and suspect this may be creating some of the problems.
    Driving is the only way to go faster....
  • Jordan
    • 12916
    The external fuel pump under the drivers side rear should be the exact same part. I dont know about the intank pump tho.
    https://mtechniqueabs.com/
    • AdamF 88iS
      • 2051
      Wont work at all.
      All '88 and up E30s with the exception of M3s have a single main pump inside the tank rather than the dual setup with the external main pump and secondary in tank pump. Since super eta is '88 then you're out of luck here.
      Adam Fogg- '88 M3
      Common sense- It's the new 'gifted'
      • bmwguru007
        • 561
        88+ e30s have a single in tank pump, unlike the earlier models which have the dual pump setup. I don't know if you can get it to work.
        • bmwguru007
          • 561
          oops I knew that! ;)
          • modifiede30
            • 1208
            Can it be reconfigured to take a dual pump setup?
            • AdamF 88iS
              • 2051
              You'd have to swap gas tanks to make it work. Rock on if you do it though; the older style setup is superior.
              Adam Fogg- '88 M3
              • Mystikal
                Wheel Fitment Expert
                • 9602
                Really? How come? Not trying to be ignorant, just really don't know why.
                • AdamF 88iS
                  • 2051
                  Reliability is the main thing. The big single pumps burn out faster.
                  Adam Fogg- '88 M3
