brake lights staying on
  • Ceeker
    • Sep 2009
    • 2821
    So, I put the car in accessory mode before even starting and my brake lights are staying on. the warning indicator in the overhead is telling me brakes. So I go out to look and sure enough lights stay on regardless of whether the pedal is being applied or not.
    any suggestions would be helpful. thx.
  • Ayman
    • Apr 2011
    • 4190
    Brake light switch behind the pedal?
    Edit: lol at my lack of English skills
    Originally posted by yert315
    Your mother is plug n play
    • Cletonius
      • 2809
      Originally posted by howdyhoayman
      Break light switch behind the pedal?
      This. I may have the switch on a parts car if you need it and its the same for an auto trans late model as what you have.
      - Josh
      1990 325is
      Need a shift boot?
      Looking to buy shift boot frames, PM if you have one to sell
      Here's what happens when you let the internet pick your license plate
      • rhE-30
        • 498
        If you've made any adjustments, the pedal may not be contacting the switch or one of the connectors may have come loose. Try to adjust it before replacing it.
        • jw 325ic
          • Sep 2006
          • 1360
          They can get stuck with age/dirt etc. just replace it, theyre like $10-20 and should last another 10-20 years...
          • Tismael711
            • 791
            I had the same problem last month....it was the brake light switch.
