Moonroof question
  • Cletonius
    • 2809
    Moonroof question
    So I picked up a moonroof over the weekend and it appears one of the brackets bonded to the glass isn't completely bonded anymore. Anyone know what adhesive I would use to take care of this? Would a good glass and trim shop be able to refurb the panel?
    - Josh
    1990 325is
    Need a shift boot?
    Looking to buy shift boot frames, PM if you have one to sell
    Here's what happens when you let the internet pick your license plate
  • Ceeker
    • Sep 2009
    • 2821
    I have the same problem; one of mine let go trying to fit the roof to work. A glass trim shop will use Urethan. it will NEVER come off after using that.
    • Cletonius
      • 2809
      It's been a challenge trying to find someone wanting to do the job. I've been told to "just get a new one" more times than I care to hear. One guy said he would just cover everything with urethane adhesive and it would "probably" be ok. The search continues...
      - Josh
      1990 325is
      Need a shift boot?
      • Simon S
        • Oct 2004
        • 3758
        2 part epoxy?
        -----Zen and the Art of e30 Maintenance - / - Zen TOC - / - Zen Summary
        • 4drPwr
          • 370
          Japandrew re-bonded his, I don't remember what he used. May be worth searching through his posts for some inspiration.
          86Zinno
          • Cletonius
            • 2809
            I was checking out his threads and couldn't find the details on the rebonding, and all the pics are gone. If anyone has any of the pics I would appreciate a copy.
            I talked to a few more glass shops today and I'm pretty sure it will have to be a 2-part urethane based adhesive. I'm trying to find a source where I can get a small quantity.
            If it ends up where I can't get a little bit I found a glass shop about an hour from me that seemed interested in giving it a try. He sounded pretty confident so I may bring the glass out there and get a for real quote.
            - Josh
            1990 325is
            Need a shift boot?
            • Cletonius
              • 2809
              So after scouring the internets I think I found a suitable reasonably priced adhesive.
              What do you all think?
              - Josh
              1990 325is
              Need a shift boot?
