Just rebuilt my driver's side door lock cylinder. All four doors lock and unlock manually. Locking the passenger's door will lock three doors, but not the driver's side. Unlocking passenger or driver's side will unlock all the doors. Lockign the driver's side will not lock the rest of the doors. I haven't checked the trunk. Any ideas as to the likely cause of this problem?
Central locking ?
most likely is a bad actuator failing to send a "lock signal" to the central locking module
August R3VLimited Special: E3012 "V3" box: $225 shipped
Tutorials: Killer $500 Stereo | E30 Vert Dual 8'' Box Installation | E3010 Amp Rack Installation | Radio Wiring and Amp Bypass -
So what kind of repair am I looking at? I assume the problem is in the driver's door, does that make sense? I had a hell of a time getting the door lock cylinder out and back in because sedan doors have a lot more sheet metal than coupe/vert doors. Is the actuator inside the door as well? I've read about something related to central locks that lives behind the driver's side footwell speaker panel.Comment
That's just the control box, if you can lock everything from the passenger door or the trunk then that isn't your issue.
Originally posted by ROLLingKINGi have a bronzit and plan on making it look sweet.Originally posted by slammin.e28Moral of this story?
If you drive your e30 on stairs, you're gonna have a bad time.Comment
Tutorials: Killer $500 Stereo | E30 Vert Dual 8'' Box Installation | E3010 Amp Rack Installation | Radio Wiring and Amp BypassComment
and the ETM is as clear as mud
