Any way I can pull my OBD/CEL code myself?
  • Joey Link
    drunkest guy at Oktoberfest!
    • Nov 2004
    • 1176
    My car's check engine light comes on then goes off at random times and the car has an idle surge problem, I believe they're related. I can most likely fix it myself, but I want to know what's wrong before I go shootin in the dark and spending a bunch of money. Before I take it somewhere, is there any way I can pull the code myself? Someone on bf.com mentioned there's a gas pedal method but after an exhaustive search of multiple boards, I can't seem to find it.
    *EDIT* figures, right after I post I find it.
  • parkerbink
    • Jun 2004
    • 10138
    Displaying Fault Codes for Motronic 1.3 (E34 5 Series, etc)
    Using Motronic 1.3, The ECU (Engine Control Unit) remembers fault codes if problems develop while operating. When a problem is detected, the ECU stores the fault code and then flashes the Check Engine light. Normally these codes are retrieved using a scan tool plugged into the diagnostic connector. There is an alternate method to read these codes if no tool is available:
    1. Turn the ignition key to the run position.
    2. Depress the gas pedal to the floor five times in rapid succession. (Activates the wide open throttle switch)
    3. The ECU then displays the error codes by flashing the check engine light in a sequence that corresponds to the code. Eg: Error Code 1222 is displayed by flashing once, then pausing, then flashing twice, then pausing, then flashing twice two more times. If there are no faults, you should see the 1444 code, or 2444 if you have a 12 cylinder model. 12 cylinder models have additional codes for the second Motronic ECU. The code replaces
    the first digit (1) with a (2).
    Motronic 1.3 Fault Codes
    Fault Code
    Malfunction
    1211 DME Control Unit
    1215 Air Mass/Volume Sensor
    1216 Throttle Potentiometer
    1218 Output Stage, Group 1
    1219 Output Stage, Group 2
    1221 EGO(O2) Sensor 1
    1212 EGO(O2) Sensor 2
    1222 Lambda Control 1
    1213 Lambda Control 2
    1223 Coolant Temp. Sensor
    1224 Intake Air Temp. Sensor
    1225 Knock Sensor 1
    1226 Knock Sensor 2
    1227 Knock Sensor 3
    1228 Knock Sensor 4
    1231 Battery Voltage/DME Main Relay
    1232 Throttle Idle Switch
    1233 Throttle WOT Switch
    1234 Speedometer A Signal
    1237 A/C Compressor Cut Off
    1242 A/C Compressor
    1243 Crankshaft Pulse Sensor
    1244 Camshaft Sensor
    1245 Intervention, AEGS
    1247 Ignition Secondary Monitor
    1251 Fuel Injectors (group 1)
    1252 Fuel Injectors (group 2)
    1253 Fuel Injector 3
    1254 Fuel Injector 4
    1255 Fuel Injector 5
    1256 Fuel Injector 6
    1257 Fuel Injector 7
    1258 Fuel Injector 8
    1261 Fuel Pump Relay Control
    1262 Idle Speed Actuator
    1263 Purge Valve
    1264 EGO Heater
    1265 Fault Lamp (check engine)
    1266 VANOS
    1267 Air Pump Relay Control
    1271 Ignition Coil 1
    1272 Ignition Coil 2
    1273 Ignition Coil 3
    1274 Ignition Coil 4
    1275 Ignition Coil 5
    1276 Ignition Coil 6
    1277 Ignition Coil 7
    1278 Ignition Coil 8
    1281 Control Unit Memory Supply
    1282 Fault (Code) Memory
    1283 Fuel Injector Output Stage, No Cyl#
    1286 Knock Control Test Pulse
    1444 No Failures
    Copyright ? 1999 Richard Nott
    • Joey Link
      • Nov 2004
      • 1176
      Thanks! :D
      • Jand3rson
        • 37587
        Does pulling the codes with this method still work if your ECU is chipped?
        • e30sd
          Fistee
          • Jan 2004
          • 5517
          yes
          • AdamF 88iS
            • 2051
            Only applies to Motronic 1.3, which means the end of 88 and up. 87s and early 88s have 1.1, it flashes the single digit codes by itself just by turning the key on without starting.
            Adam Fogg- '88 M3
            Common sense- It's the new 'gifted'
            • parkerbink
              • Jun 2004
              • 10138
              My 90 works like this with MarkD's chip.
