Tape player ate my Tape!
  • bimmer8604
    • 3017
    How do I get a tape to eject if the stupid thing wont eject on its own?
    Kyle
    1988 M3, 97 840, 99 XJ
    DILLIGAF
  • Jon325i
    • 6934
    Kyle
    You openly admit to still using a tape player? Perpare to be flamed :P
    As to resolving your issue....did any odd noise occur when you inserted said tape? If this is the OEM unit it could be a case of a worn part failing. I'm no stereo expert....heck I can barely install one. My M20/Stromung soundtrack is all I need :-D
    Jon
    Rides...
    1991 325i - sold :(
    2004 2WD Frontier King Cab
    RIP #17 Jules Bianchi
    • SchnellerVert
      • Sep 2005
      • 3948
      come to the digital age man.... throw it out. Just say no to analog.
      • bimmer8604
        • 3017
        Well, considering i preferre the look of the stock HU over some of these new ones, and that most aftermarket HU's dont sit flush with the rest of the center consul, and the ones that do cost way too much than I would be willing to pay for a CD player, and that i have a CD changer, and maybe sometimes I like to play some tapes.
        Soo much for wanting a cars interior to look clean and original.
        Kyle
        DILLIGAF
        • Charlie
          kid tested, administrator approved
          • 6686
          Fuck bro, how are you gonna play your Color Me Badd tape now?
          -Charlie
          Swing wild, brake later, don't apologize.
          '89 324d, '76 02, '98 318ti, '03 Z4, '07 MCS, '07 F800s - Bonafide BMW elitist prick.
          FYYFF
          • bimmer8604
            • 3017
            I dunno, i LOVE that tape.
            I think I love it more than my TOp Gun Soundtrack!
            Kyle
            DILLIGAF
            • B2ThaZiZza
              • Aug 2004
              • 614
              You need to get the Eagles hell freezes over tape!! One of my utimate faves!!
              • bimmer8604
                • 3017
                no, i have that one on CD. lol.
                Kyle
                DILLIGAF
                • B2ThaZiZza
                  • Aug 2004
                  • 614
                  I had it back in day when tapeplayers where still "cool"
                  • ///M42 sport
                    • 3952
                    I had this happen and tried to pry the tape out with a screwdriver. Needless to say that was a bad idea. Best thing is to take the whole receiver out and see if you can see which part is getting stuck.
                    • DJB
                      • Oct 2005
                      • 195
                      Which radio model do you have?
                      Alpine 9507?
                      Remove the radio, and look for a slot on the top. Sliding a screwdriver down this slot will release the tape.
                      My guess is that this will not work. Remove the top (use the proper #1 philips driver or you will strip the screws) and help the tape up as you slide the lever that was under the slot. You'll need the top metal plate to locate the proper point on the mechanism, as it's not obvious.
                      Use a foam swab and alcohol to clean off the mechanism.
                      Oh, you may need a 5 sided driver to release the clamps that hold the radio in. If you don't have one, buy a dollar store tiny screwdriver set. A cheap slotted driver will be soft enough to jam in the screw, where a good quality hardened screwdriver won't work.
                      • bimmer8604
                        • 3017
                        Alpine 9507?
                        First post, and I allready like you. You will fit nicely in here.
                        Kyle
                        DILLIGAF
                          • 37828
                          Kyle, I know how to fix it...
                          Step 1, remove stock head unit
                          Step 2, throw it away
                          Problem solved
                          Classic BMW Specialists
                          Grover Beach, CA
                          www.BimmerHeads.com
                          • h0lmes
                            Whats a tape?
                            • 325Projectz
                              • Jan 2005
                              • 1956
                              Get a z3 deck.
                              91 m3
