Proper way to connect gauges
  • ezlnh8u
    • Feb 2012
    • 254
    Hi there, everyone, i want to install after market gauges for fuel and water temp, anyone have a diagram on what wires i need to tap into?, i already have the pod and the gauges,
  • 89 e30
    • 249
    What's wrong with the OEM ones
    BIMMER für IMMER
    • JinormusJ
      • 6887
      • JinormusJ
        • 6887
        INHO, anything besides OEM, or anything aftermarket that is not ForFunctionalsSake does not belong in an e30...
        I don't honestly have your answer, but just offering my 2 cents
        Ultimately it's your car, so your doing what you want to it. No skin off my nose
        But if it's some crazy cluster that is supposed to read goodness from a twin-turbo s54, please share pics :up:
        • ezlnh8u
          • Feb 2012
          • 254
          the gas and temp and also the rpm does not work on my cluster, i asked in the forums about what could be the problem, now one was able o answer, i asked for help, and not to be judged, thanks anyways.
          • dnguyen1963
            • Nov 2011
            • 2651
            Replace your SI board. Programma for @ $160.
            • samiam3356
              • Jul 2009
              • 1901
              This shit will get you ran out of here. Trust me
              Plenty of people run aftermarket guage on here.
              I would look threw the project forum and see which way you like best and copy one of those.
              Originally posted by Roysneon
              $5 shipped?
              Originally posted by MarkD
              You are a strange dude, I'n not answering any more posts from you.
              • 89 e30
                • 249
                Just replace the batteries on the si board
                BIMMER für IMMER
                • reelizmpro
                  • 9558
                  Your factory gauges don't work so u rather install aftermarket ones? It's likely an easy fix too. Change the SI board and tighten the nuts on the fuel and temp gauge while you are there.
                  88 M3 - LACHSSILBER
                  89 M3 - ALPINEWEISS II
                  • ezlnh8u
                    • Feb 2012
                    • 254
                    Thanks for advice fellas, will recheck the si board
