does the super eta control fit into a regular eta?
  • schnitzer teil-jäger
    • 661
    is the super eta brain an upgrade for a regular eta? does it fit? rpm is higher.
    wes
  • rs4pro3
    • 5808
    I don't think so as the Super eta uses Motronic 1:1 and uses a 325i wiring harness with the tripple row conector. I could be wrong but If I rember correctly this is how the super eta was at the yard I worked at.
    85 325e 2.7 ITB'd stroker
    • reelizmpro
      • 9558
      Re: does the super eta control fit into a regular eta?
      wes
      No, it's different.
      88 M3 - LACHSSILBER
      89 M3 - ALPINEWEISS II
      • slammed_e30
        • 514
        Yup won't work
        Originally Posted by Rob
        fucking hell, your car is cleaner in the damn snow than mine ever has been in perfect weather. sedans own me.
        • e9nine
          • 1890
          super eta uses crank sensors, reg eta uses flywheel sensors. Motronics versions are different, plugs are different and so are some other petty items. I'd look further into this before attempting this if I were you. There is no "gain" in comparison to the hassle involved...
          EDIT: Woooops :D , look what u started!
