intermittent starting issue
  • chappys4life
    • Aug 2011
    • 132
    I have been having issues with my 87 325e lately occasionally it just will not start. It cranks just spinning, after trying multiple times it starts sometimes or if I let it sit for like 10 minutes it starts. When it started doing it I thought it was the tps as I had an erratic revving (even after replacing the air hoses related) so thought it might be it but nope still doing it.
    About 7 months ago I replaced the fuel pump relay for doing a similar thing but it would spin or occasionally start and run like crap and idled around 500-1000 rpm then slowly dropped and died. Also I replaced the main relay as I was at the bmw dealership and it was cheap. In August I did timing belt, water pump, plugs, fuel filter, cap, rotor.
    Any ideas of things to test or try?
  • bmwstudent
    • Sep 2011
    • 1364
    Next time it doesn't start, pop off a plug wire and check for spark. See what you don't have (spark or fuel) assuming you have compression. Then investigate. Check your pm, the fender is in Richmond.
    • chappys4life
      • Aug 2011
      • 132
      I think it was a fuel issue. Purchased a new fuel pump relay again its been working. Think I am going to buy new fuel pumps.
      • bddog
        • 351
        Sounds like a crank position sensor.
        • navid41691
          • Apr 2011
          • 677
          • chappys4life
            • Aug 2011
            • 132
            Even though it's been running fine all week?
            • shoshottz
              • Jun 2016
              • 125
              any definitive solution?
              Sent from my iPhone using Tapatalk Pro
              • locar
                • Dec 2012
                • 64
                I'm going to second this:
                When was the last time the Speed and Crankshaft Position sensors were replaced on your car? I just dealt with this and replacing both fixed it. Make sure you order by the Bosch part numbers to save some $$$. There's two different one's that will work. The more expensive one just has longer wires.
                • shoshottz
                  • Jun 2016
                  • 125
                  fixed my problem. ended up being the external fuel pump
                  • e30davie
                    • Apr 2016
                    • 1788
                    I reckon there are a lot of perfectly good crank sensors that have been thrown in the bin.
