Upgraded Ground Wire Kits?
  • 808BMW
    • 2910
    #31
    Originally posted by NC325iC
    id say thats still alot of money for some wire that someone cut to certain lengths... itd be just as good to let me cut my own wire and just tell me where to attatch it
    1) Battery negative to chassis
    2) Alternator to battery positive
    3) Chassis to engine
    Make sure to fuse #2 with a large fuse.The fuse should be sized to match the max ampacity of your wire, not the output capability of your alternator.
    I will use 0 gauge and a 300A fuse.
    • ryan_george
      • Mar 2004
      • 331
      #32
      I also don't understand why these "kits" are so expensive..... Spend $15 for 20' of 4 awg, another $10 for terminals, and bam... you're done, and you've saved well over a hundred bucks....
      • formula driver
        • 2263
        #33
        Give it a couple months and bam... your kit will have distroyed itself.
        • royalflush313
          • Mar 2004
          • 2070
          #34
          your kit is basically what ryan_george described, except we don't need to do any work as yours are pre-cut to the right dimensions, no?
          So our DIY will somehow explode to its unnatural and agonizing death, but your kit, someone superior in quality will withstand from supernatural extinction?
          Explain, please.
          ~ Go Canucks Go! ~
          • golde30
            • 11464
            #35
            Explain, please.
            +1.
            IG: @Baye30
            • sharkd
              • Apr 2005
              • 82
              #36
              Ha! My grounding kit out-grounds all of yours -- for the simplest, purest path to ground, I simply run a heavy gauge wire from my positive terminal to my negative terminal.
              Voilá! Maximum Groundage!
              “one of the most beautiful BMW’s ever...”
              • ryan_george
                • Mar 2004
                • 331
                #37
                Yes, I'd also like to know how my wire and terminals are different from your wire and terminals. :ohsnap:
                • formula driver
                  • 2263
                  #38
                  Most cant withstand the heat under the bonnet. Guys I havent been answering questions here for a reason. If you want information on these PM me.
                  • 318isbmw
                    • Nov 2005
                    • 2843
                    #39
                    Just go to a local parts place and pick up either just the wires and then terminate them, or you cna buy them at a pre set length, even tho woven metal ones for the motor grounds and such. Just my .02 cents
