Ranom no-start scenario - Ground, starter, alternator??
  • Turf1600
    • 9815
    So, just recently my car started behaving erratically. I'll turn the key and it'll go "Click!" but not start. I turn the key again - same thing. Sometimes I'll turn the key 25+ times and nothing. And then randomly it'll fire up. I turn it off - try again...."Click!".
    Anyone have this issue before? Is it my starter? I've never had a starter behave like this. Usually I'd bang on it with something like a breaker bar. This has no effect on my current situation.
    I'm thinking it could be my alternator - but then why the random starts?
    Any help is appreciated...
  • Kershaw
    • 11822
    sounds like a ground issue to me.
    AWD > RWD
    • Exodus_2pt0
      • 5943
      ^ Agreed.
      Check your main engine ground. Mine would act up randomly, and when I finally got sick of parking only in spaces that would allow me to push start it, I replaced it. Now I could park at the bottom of a sand pit.
      No E30 Club
      • Turf1600
        • 9815
        I looked and I don't even see one. Is it hiding from me?
        • Exodus_2pt0
          • 5943
          You gotta pull the air box.
          No E30 Club
          • Turf1600
            • 9815
            I'm just going to use that article you posted to replace all of them.
            • bmwguy325is
              • May 2011
              • 1263
              A solenoid can still make the click click and be bad. The banging on the started only check the brushes. What you are doing is as the brushes wear they ground to the case and you bang them off.
              Pull the starter and bench test it. You can do it your self with a friend and jumper cables.
              sigpic"If one does not fail at times, then one has not challenged himself." -Ferdinand Porsche
              The ugly car: http://www.r3vlimited.com/board/showthread.php?t=209713
              • Exodus_2pt0
                • 5943
                KISS method is better than immediately pulling parts.
                KISS. Keep It Simple, Stupid.
                Checking a ground cable is less work than pulling the starter, and just as likely to be the cause.
                No E30 Club
                • Turf1600
                  • 9815
                  There's no way I'm pulling the starter. That's a bear of a job. I'm going to replace my grounds and hope for the best. They probably need to be replaced anyways - I have all of the other symptoms of bad grounds.
