e30 323i problemzz plz help
  • kushesh
    • 55
    hi guys
    i got a e30 323i 1986 conv the problem im having is that the car starts but does not rev up pass 1000rpm i put a new afm but still the same
    wud it be the computer box?
    i put my friends e30 320i 1986 computer box in and does not even start up
    is there a diff between a 323i an a 320i comp box?
    i opened the the computer box out and there is abit of rust on the one side of the circuit board
    plz help guys
    thanks
  • James Crivellone
    Head Janitor
    • 6305
    Check for a good ground on the spark generator (on the firewall blower motor cover)
    • Court M3
      • Jan 2004
      • 6713
      if you happen to need a comp send me the number off yours I might have one soon
      Continuous For Sale Thread
      323i s50
      • kushesh
        • 55
        thanks guys
        so youll think it cant be the computer box?
        • kushesh
          • 55
          court m3 thanks but how will i get it to South africa
          • Jordan325iC
            • Aug 2005
            • 1697
            I'm nearly certain that putting a "computer box" from a diffrent model car into your car will cause it to not start. Your dme numbers have to match (found on the bottom of your ecu).
            '88 325is
            VP UT of Austin Autoholics
            BMWCCA 380364
            • kushesh
              • 55
              ok guys put another comp box with same numbers still not working could it be the fuel pressure from the pump?
              • James Crivellone
                Head Janitor
                • 6305
                check the distributor, it should have a little connector on the side which has 2 wires on it (may be 3, been a bit since I've looked)
                Make sure that is nice and tight, otherwise it won't know engine RPM.
                I presume this has the L-Jetronic ECU? If it won't go above 1000 it sounds like the spark generator has no idea what the RPM is. Just a hunch though.
                • kushesh
                  • 55
                  thanks james
                  it does a have a jetronic system
                  where would i find the spark generator?
                  could it the fuel pressure from the pump?
                  thanks again
                  • James Crivellone
                    Head Janitor
                    • 6305
                    thanks james
                    thanks again
                    Its mounted on the blower motor cover (firewall) small little silver plate with a rubber cap on it, with a connector coming down.
                    Its near the fusebox.
                    • A_325i
                      • Jun 2005
                      • 680
                      did you plug the afm in?
                      • kushesh
                        • 55
                        yes i did
                        could it be the fuel pressure regulator?
