black plastic piece that holds the trunk seal on...how do i get the connectors off?
  • 90pioneer
    • Jul 2011
    • 78
    I need to remove the black plastic peice that spans the width of the trunk and holds down the trunk seal.
    Is there a trick to removing the connectors? I'd rather not break them if I don't have to...
    • 34839
    push the center pins down through the trunk. if you take out the trunk liner, you can retrieve them.
    • bmwstephen
      • 2463
      take a phillips screw driver and hammer the plastic pins through and it should contract the internal rivets for you to pull it straight up.
      you can collect the pins after.
