Setting the time and date on the onboard
  • ezlnh8u
    • Feb 2012
    • 254
    Anyone know how to set the time and date on the onbaord computer on the e30s? i cant figure this thing out, and its also so dim, can led's be installed? thanks.
    In order to reset the OBC you need a paper clip or a pen. Stick the paper clip in to the small hole next to the number one in the bottom rig...
    The display is probably dim because one of the backlight bulbs has burned out. The easy fix to to get a new bar. The bulbs can be replaced, but at $20 for the light it hardly seems worth the effort.
    • dnguyen1963
      • Nov 2011
      • 2651
      I replaced the bulb with LED. Simple procedure...you need to get some high intensity amber LED (search the internet - 100 LEDs for @ $5). You also need some 330 ohms resistors from Radioshack. Follow this procedure.
      To set the time, get a small pencil and push a little indent on the bottom right corner to get to the setting mode. The procedure is in Bentley if you cannot figure it out, but it is pretty straight forward.
      • ezlnh8u
        • Feb 2012
        • 254
        thx guys
        • george graves
          • 20003
          They are more like $36 shipped - just FYI.
          Originally posted by Matt-B
            I recently bought a bar from my dealer for about $20.
