Water leaking in passenger floor
  • chop_suey
    • Nov 2009
    • 270
    I have water leaking into the passenger side floor. The water is entering around where the AC lines come in thru the firewall. What did you guys do and use to seal this leak? I was thinking some clear silicon.
    thanks for the help.
    85 325e 5spd
  • McGyver
    • 4636
    have you checked to see if the elephant drain is clogged? it looks sort of like an elephant's snout coming out of the fire wall above the exhaust. pull it off and rinse it out.
    • Todd Black 88
      • Oct 2007
      • 3449
      I have the exact issue. Have not got it sorted yet
      Also water gets past my heater core gasket when it rains heavily, and also the heater core gromet for he lines........fucking sieve.
      All drains are clear.
      Originally posted by codyep3
      I hope to Christ you have looks going for you, because you sure as fuck don't have any intelligence.
      2001 silver/Blk 325 cabby. SOLD
      2002 325xit Sil/blk. SOLD
      2010 F650gs twin
      • chop_suey
        • Nov 2009
        • 270
        ya the ac line grommet is the place. elephant tub is fine.
        Ive put some clear silicon around the gtommet an line, but still the water manages to come in when i hose the area.
        85 325e 5spd
        • chop_suey
          • Nov 2009
          • 270
          bump for what to use to seal this area?
          85 325e 5spd
          • Todd Black 88
            • Oct 2007
            • 3449
            I found my leak to be cracked seam sealer where the water from the passenger side grill dumps into the fender support. It drains forward towards a seam that seals the two pieces of metal under the ac grommet. You have to reach up under the fender, look at where the water dumps into the fender, and you will see this seam.
            I used automotive seam sealer, and all is dry now.
            2010 F650gs twin
            • chop_suey
              • Nov 2009
              • 270
              will take a look, thanks
              85 325e 5spd
              • Sindako
                • Nov 2012
                • 116
                OK ,
                1. Remove You Battery
                2. Remove The Non-Slip Rubber under the battery ( At the battery Stand ) .
                3. Check Out for Rust and Drain . ( Had That Problem because Old Batteries Used to Boil Sometimes )
                If You Find The Battery Place Safe and Good .
                Check Out Your Drains behind The AC Blower Cover , and Clean It Good .
                Last Thing , Remove This Drain In The Photo
                Clean it Good and Then Put it back In With Some Gasket Maker Around The Metal to make sure it's 100% Attached.
                Hope This Will Solve Your Problem .
                Other-Wise , you'll Need a Dashboard Removal and a Sunroof Drains Check .
                • chop_suey
                  • Nov 2009
                  • 270
                  cracked seam sealer is the problem, seems small but bigger than it looks. sealed it, letting it dry and see the out come l8r. thanks todd black 88
                  85 325e 5spd
                  • ErickEnriquez
                    • Jan 2018
                    • 121
                    This is the same problem I’m having. Can’t find where the cracked seam is. Could anyone show me where theirs was?
