Problem with my car running hot and temp gauge jumping around...
  • Joey Link
    drunkest guy at Oktoberfest!
    • Nov 2004
    • 1176
    Tonight on the way home from the meet I noticed my car was running a little hot, right on the first mark (I guess that means 1/4th?). Normally it runs about two needle-widths below that. As I got on the freeway I noticed it went up to the half mark, then fell back down quickly, then slowly rose back up. When I parked I could see the needle jumping maybe every few seconds very quickly, but only a few needle-widths. Not sure what this is, is my temp sensor going out? Thermostat probably isn't the culprit, but I'm not sure. Anyone experienced this before?
  • kencopperwheat
    King of Kegstands
    • 14396
    You probably need to replace you SI batteries on your cluster board. However, I would try tightening the grounding nut on the back of the temp gauge first.
    Originally posted by Gruelius
    • e30frosh
      • Dec 2004
      • 2170
      My thoughts exactly, the ground nut was loose on my 90 325i. Solved the happy needle quickly.
      Every day I wake up we drink a lot of coffee and watch the CNN
      Every day I wake up to a bowl of clover honey and let the locusts fly in.
      Lobsterbacks attack the town again
      Wrap all my things in aluminum
      Beams of darkness streak across the sky
      Pink rays from the ancient satellite
      Every time I look out my window same three dogs looking back at me.
      Every time I open my windows cranes fly in to terrorize me.
      • StereoInstaller1
        GAS
        • 22679
        Joey, I would take the SI board out...I bet yours is the kind without batteries. Either way, it would be good to know if a maintenance issue is there, waiting.
        I have had my batteries and battery holder waiting to go in for nearly as long as I have had my car.
        Luke
        Closing SOON!
        Thanks for 10 years of fun!
        • Digitalwave
          is a poseur
          • 6293
          Your car normally runs BELOW the first 1/4 mark? That is too low... it should at least be between the 1/4 and 1/2 mark once its heated up. Your thermostat might be broken open.
          RISING EDGE
          • Joey Link
            • Nov 2004
            • 1176
            Yeah normally runs below. Maybe I should replace the thermostat?
            • kencopperwheat
              King of Kegstands
              • 14396
              I'd inspect it. It might also be the coolant temp sensor.
              I'd definitely take your gauges out and tighten the grounding nut on the back of the temp one though.
              • Digitalwave
                is a poseur
                • 6293
                Even if its not broken I would, and replace it with a higher temp thermostat because its not good for your car to run that cold.
                RISING EDGE
                • Jordan
                  • 12913
                  Water temperature, and oil temperature are 2 totally different things TEEJ.
                  Cooler the water the better. Wicks more heat off the head and helps the engine make its optimum power.
                  https://mtechniqueabs.com/
                  • Digitalwave
                    is a poseur
                    • 6293
                    I know they are different, but you are saying its good that his car's water temp is always below the 1/4 line?
                    RISING EDGE
                    • hamann318is
                      • 3382
                      There is a reason there is a thermostat. If BMW wanted cold motors, why even bother throwing one in there?
                      The BMW 318 is back. With a vengeance.
                      • StereoInstaller1
                        GAS
                        • 22679
                        because people want a heater?
                        LF
                        Closing SOON!
                        • SebSter
                          • May 2004
                          • 192
                          My car has been running like this for 3 years. Changed the thermostat and no help, still stays near the 1/4 or just above it. The heater only heats at FULL red position, otherwise just cold air blows in (in the winter that is).
                          1990 325ix
                          • Jordan
                            • 12913
                            Ding ding ding.
                            • E30 Wagen
                              where is this grounding nut you speak of? It seems mine might need to be tightened as well.
