ok, so I decided to mess around and check my spark plugs today. pulled the #6 spark plug out and it was sorta wite-ish. as I recally that means the engine is running lean... so I open up the cap to my AFM and tighted then spring by one click. then put everything back together...
then I went ahead and removed my rear seats cuz they were sorta nsaty and I didn't really need them, so I put them in my storage.
not, I decided to go out and get some food... lo and behold when I start my car, I was having a surgine idle problem!! so I pop the hood and check all the plug wires to make sure I plugged everythng in tight... yes I did.
so WTF?? I just held my foor on the gas so it would stay at 2k... the engine didn't fluctuate when I did the tho. once the car warmed it, it was having a rough idle, so I opened up the icv a bit to let it idle ~ 950. I drive about a mile to food, then I notice the idle at ~ 1.1k... so I close the icv back to it's original setting and the idel was still sorta high, so I lower it to about 750~800 where it should be. idle didn't really move too much now, but I've got a feeling that something's wrong.
any suggestions? what could be the cause of a surging idle anyways? my icv is clean, and afm works fine... ??
