Fuse 6 :[
  • george graves
    • 19996
    Replace fuse with wire. Problem solved.
    Originally posted by Matt-B
    • delatlanta1281
      Dart Master
      • Mar 2006
      • 10317
      or you will figure out where it stems from!
      Run it with out the radio in the car... maybe it's a short inside the radio?
      Yours truly,
      Rich
      you kids get off my lawn.....
      • 93zk
        • Sep 2011
        • 60
        what just take a pieces of scrap wire and "U" it into where the fuse is supposed to go? wouldnt that cause other wires to short and burn up?
        • LJ851
          • 7919
          replace fuse with 22 gauge bullet, 1 problem solved.
          Lorin
          The M30 is God's engine.
          • delatlanta1281
            Dart Master
            • Mar 2006
            • 10317
            possibly.
            Yours truly,
            Rich
            • 93zk
              • Sep 2011
              • 60
              could that fuse blown cause the engine cutoff problem?
              • george graves
                • 19996
                I was joking - don't replace fuses with wire.
                • 93zk
                  • Sep 2011
                  • 60
                  i should do it so i can see where the shortage is. maybe it can set my car on fire so i can buy a new one
                  • McGyver
                    • 4612
                    hahaha, now you ruined a parts car!
                    • 93zk
                      • Sep 2011
                      • 60
                      its about to be a parts car if i cant get it fixxed. a parts car for the shell im thinking about getting. but how would i be able to build one if i cant even figure out a simple shortage problem
                      • Wh33lhop
                        • 11705
                        Originally posted by Stanley Rockafella
                        for no raisin.
                        Either english is not your first language or you are a comic genius.
                        paint sucks
                        • 93zk
                          • Sep 2011
                          • 60
                          or im 19 and its shocking that i graduated high school. who needs english anyways.
                          • delatlanta1281
                            Dart Master
                            • Mar 2006
                            • 10317
                            QUOTED IN MY SIG!!!!!!!!!!!!!!!!!!!!! Don't give up, figure it out. remove everything listed one at a time. Do you have a sunroof leak? Could be the wires in the check panel.
                            Yours truly,
                            Rich
                            • Kozworth
                              • May 2011
                              • 1339
                              lmao.. so I would assume for a fuse to pop there has to be a short after the fuse.
                              Check the wiring diagram for whatever fuse 6 falls under, and check the wire/gauge that comes after that. You can inspect it wire by wire for any cuts in insulation that might ground to other circuits/body. See if any other things dissapear when that fuse pops, and it could help you track which wire is being shorted.
                              • 93zk
                                • Sep 2011
                                • 60
                                its not the check panel i looked at that. i do have a trunk leak though which causes the central locking not to work when it rains sometimes.
