OK so ive been experiencing a poor idle condition, witch is at its worst on cold startup, the engine surges, sometimes stalls and idles low at 500-600 rpm. This has been happening for almost the whole time ive had the car about 2 years.
So I have tested (and, or) replaced the following items.
Mass airflow meter
Tested every know electrical connection
New plug wires
Idle speed motor
Throttle position switch
Coolant temp
Checked fuel presser
Cleaned and tested injectors
Crank sensor
Swapped ECM’s and chip
Tested for vac leaks
Also over the summer I rebuilt the top end, just because I felt like it not to solve the problem. So an extra interesting detail is if I reset the ECM buy disconnecting the battery or the connector for about 20 minuets, the car starts cold idles exactly as it should for about 3-5 start cycles, than reverts back. There is an item ive recently been suspecting as the culprit but am not mentioning it so I can get unbiased answers. I know some of you have extensive experience with 1.1 motronic so any assistance would be appreciated. End of rant.
Mass airflow meter
New plug wires
Idle speed motor
Coolant temp
Crank sensor
