a thud
  • mrsleeve
    • Mar 2005
    • 16387
    a thud
    ok heres the deal I finished up the suspension work last weekend (cup kit, SFB,TAB, are IE, new control arms THR CAB, and new brakes all around)
    Tonight When I was in town and in parking lots makeing slow speed turns with the clutch out I would get a verry audiable clunking/ rubbing sound comeing from the rear. If had the clutch in no noise, which makes me think it's something to do with the LSD.
    any ideas anyone
    thanks
    Originally posted by Fusion
    William Pitt-
  • erik325i
    • Jan 2005
    • 3567
    did you replace your rear shock mounts?
    • mrsleeve
      • Mar 2005
      • 16387
      yup forgot those IE billets with the steel reinforcment plates
      William Pitt-
      • mrsleeve
        • Mar 2005
        • 16387
        ok to day I went through the whole ass end of the car and nut & bolted everything I took apart, everything is tight. Also there are no wear mark on anything, so now I am relly confused as to where the hell the noise is comeing from.
        One other thing, I made a run to the gas station and hardwear store (8 mi round trip) with no noise no matter what the clutch position. Till I got back home and was comming up the drive.
        Little help here, I am at a loss
        William Pitt-
          • 34844
          ghost noises :(
          I have them too, but I suspect my problem is a worn rear driveshaft. but every time I check it out back there everything is tight.. oh well, it's all coming apart again next year so hopefully I get it sorted out. :)
