This is on my 181K '87 325is.
A few days ago, my car was idling very poorly. It would go from 500rpm to 1000rpm and back down again. I swapped the AFM from a '90 325is over, and that didn't help much. I found a hole in the intake boot and a cracked vacuum line to the emissions bypass device. I replaced the boot with one from a '90 325IS and had to bring the ICV over as well because the boot and ICV were physically different. I also replaced the vac line to the bypass valve. After this, the car's idle was much steadier, but still very rough and only idling @ 500rpm.
Now, if the car is cold, it will start PERFECTLY and very fast. It will run for 7-10 seconds, and the idle will begin to get rough. After another 10 seconds, the idle is VERY rough, and the car is trying to idle at around 500rpm. I have replaced the above mentioned parts, as well as O2 sensor and ignition coil (everything else in the ignition system is fresh and been replaced within the last 2500 miles).
I ran through the chart of ECU tests in the bentley. That confirmed that my TPS was working properly, and lots of other stuff should be within spec as well.
Where should I start looking now?
