car doesn't want to idle correctly
  • mspiegle
    • 1026
    yeah, that's what i did when I had my 928. starter fluid works well too.
    Michael Spiegle
    '01 Ford Escape / Daily Driver
    '99 M3 / Track Car
    '87 325is bronzit / wtf car
    '06 Daytona Triumph 675 / Daily Rider
    • mspiegle
      • 1026
      Ok, I found some encouraging info...
      My CEL lights were not making sense because the 173 ECU has different codes than a 153 box (from what i'm gathering on the internet). When looking at it from that point-of-view, i'm getting code 1264 which is " EGO Heater".
      I assume that means the heater element in the O2 sensor? Is the heater element something that is controlled by the motronic unit itself? I have a brand-spankin'-new O2 sensor in there... so the problem is probably elsewhere (wiring?).
      Michael Spiegle
      '99 M3 / Track Car
      • mspiegle
        • 1026
        GOT IT!
        There is a fuse for the EGO Heater, but in the bentley it is labeled as "fuel system" (GO BENTLEY!)
        I didn't even have to reset anything... replaced the fuse and started the car to see if the fuse would pop again... fuse didn't pop and the CEL went away.
        i hope this helps someone else
        Michael Spiegle
        '99 M3 / Track Car
        • jht3
          • 288
          i'm not a fan of the Bentley or any manual that throws 10 years of a model into one book. it seems everything i look for isn't covered in the detail i'd like. it's better than nothing but it's not the be-all end-all of manuals.
          good job on tracking it down. next time you'll look at the fuses FIRST! when i lost my tach, i started digging in deep and didnt even think to look at the fuse b/c i had just replaced all the fuses. well it was a blown fuse and i felt dumb
          James
          '88 M3
          • NC325iC
            • Mar 2004
            • 6565
            yeah and the one i have doesnt cover motronic 1.3
