Is that black/green wire attached to the top post on the starter solenoid? If so, its attached..
Auxiliary fan/blower fan/ a/c issues..HELP!!
The wire from pin 15 of C101 goes to the unloader terminal on the starter. That terminal goes to system voltage when the starter is running and ground when the starter isn't running. Well, that is how it works if the unloader switch in the starter is working properly.The car makes it possible, but the driver makes it happen.
Jim Levie, Huntsville, ALComment
