I need help Orlando area soon
    I have an e30 has no spark need to get the car moving anyone in Orlando area can help I'll pay. Fuel works, just no power is getting to the coil
    what part of orlando are you in man?
      what happened leading up to it loosing spark? I've dealt with a few of these issues, and don't live too far from orlando, but I don't want to waste either of our time if I can't help.
      Have you read up in the bently manual?
        I have the car in baldwinpark let me know if you can help. Also I've. Eem doing a lot of reading I don't really understand what could have happened to cashed. I spark. I just changed spark plugs and some gaskets I've check and put new SMS and fuel injector relays checked the 50 amp fuse in the trunk. Fuel pump works so I really don't know where else to go to and I'm new to the e30 m20 engine. So if you guys can help id greatly appreciate it also Ill be willing to pay for any work done to make this car start cause the car started before all this was done. Thanks
          I think autocorrect got you on some words or phrases. Check your other thread though it might be something simple
            Ya lol sorry about that. So for the crank shaft sensor does it matter which ones goes in which slot. Also will the fuel pump work with a bad ecu. The coil is the one that's not getting Any spark. If you have the time to meet up let me know I'll pay it's some easy money. I wanna get the car started ASAP so I can pull it out of the property it's in.
              Yes it does. Sorry I can't be more helpful than that.
                yeah it does. there are two connectors near the intake boot, each with three prongs. one is for wire #6 firing sensor. Try switching those; they're identical in appearance.
