Coolant or some kind of fluid leaking
  • ezlnh8u
    • Feb 2012
    • 254
    Hello, I came across I hope is a small probblem yesterday with my 90 e30, as I parked my car to pick up my daughter, when I came back out we noticed fluid on the ground, I opened the hood and checked the to see we're it's leaking from, it's not from the water pump, but on the side of the block, same side as we're the fuse box is located, I'm guessing by the coolant drain bolt? Any suggestions?
  • dnguyen1963
    • Nov 2011
    • 2651
    How high was your coolant level in the expansion tank? If you overfilled the system it will leave a puddle after the engine gets hot. In the worst case, did you check for air in the coolant system? Hopefully, you head gasket is not shot.
    • ezlnh8u
      • Feb 2012
      • 254
      i will posting some pics and video, i found out the issue, but is there an inexpensive way of fixing this.
      • ezlnh8u
        • Feb 2012
        • 254
        A private space for your group's photos and videos. Share, react, and relive moments together. Available on iOS, Android, and desktop. Free for new sign-ups.
        • CHIF8008
          • 3447
          well nothing can be said without a thorough visual inspection of everything. just need someone that is familiar with cars that knows what to look for. if you were closer i could probably look at it for you- but im out in MoVal and have no gas monies :(
          -FREEDOM- is cruisin at 80, windows down and listening to the perfect song-thinking "this is it"
          -The Beauty in the Tragedy-
          MECHANIC SMASH!!- (you all know you do it)
          Got Drop?? ;-)
          But of course
          E30s are know to be notoriously really really really ridiculously good looking
          • CHIF8008
            • 3447
            ohh its leaking from there? (intake right?) get a new gasket- should be pretty cheap
            Got Drop?? ;-)
            But of course
            • ezlnh8u
              • Feb 2012
              • 254
              On the video you can see when i squeeze the hose, that an air bubble is created on that attachment that is conected to the throttle body, im hoping this is an easy fix, as i need this car for work tomorrow......
              • ezlnh8u
                • Feb 2012
                • 254
                can i pick this up at autozone? and what is the correct name for this part? thanks.
                • ezlnh8u
                  • Feb 2012
                  • 254
                  anyone know the name of the part?
                    It sounds like your leak is from the throttle body heater. You can get a new gasket from your dealer or on-line vendor. In the meantime, disconnect the hoses from the throttle body and loop them.
                    • ezlnh8u
                      • Feb 2012
                      • 254
                      would i need to plug up the throttle body inlet as well, or can i leave it open?
                      • SpecM
                        • Oct 2005
                        • 4531
                        You can leave them open
                        Sent from my Vortex
                        1989 cirrisblau-metallic 325i
                        • ezlnh8u
                          • Feb 2012
                          • 254
                          thx for the help, now this cant be a permanent fix right?
                          • 4drPwr
                            • 370
                            You can permanently bypass the TB heater by using a barbed hose coupler (3/8"?) and a couple of hose clamps of the proper size to insure the hoses do not disconnect.
                            86Zinno
                            • jw 325ic
                              • Sep 2006
                              • 1360
                              Ive had mine bypassed for over 10 years...
