speedometer dash wires
  • Zzyzx85
    • May 2012
    • 131
    Hey guys.
    I had my instrument cluster out of the '87 to repair the odometer and polish the lens.
    In my rush to take it out, I forgot to document where the 2 wire went into the 3 slots on the speedometer connector. One wire has a label over the sheath with some numbering on it; the other does not. Both have similar connectors that connect to one pin.
    What are these two wires and which slots do they connect to?
    Thanks in advance.
    - '89 325i 4-door, Alpinweiss, 5-spd swap (and lots of maintenance) in progress
    - '03 M3, Imolarot, 6 speed
  • Zzyzx85
    • May 2012
    • 131
    nm...found the answer: http://www.r3vlimited.com/board/showthread.php?t=196383
    So if one of the wires is for cruise control, what's the other wire for?
    Also noticed my ABS light went off. I don't know if that's because i reconnected something incorrectly or i fixed something :D.
      One of those wires is the signal from the speed sensor. The other is that signal's feed to the OBC & cruise.
      The cluster has nothing to do with the ABS other than holding the warning bulb.
