Broke the key in trunk. Now what?
  • Box400
    • May 2012
    • 16
    So my key broke off in the trunk lock.
    And the trunk is currently locked. Any suggestions on how to get into the trunk or remove the lock?
    It's a convertible so I can't go through the back seat.
  • CarsSuck
    • Oct 2005
    • 968
    How much key do you have to work with? My dad was able to remove a deeply stuck key bit using dental picks. He may have used some tiny ass pliers to pull it, but i think it was all picks. Lots of patience required.
    If the whole key is in there just push it all the way in and rotate the cylinder with a tiny screwdriver to unlock.
    --Will
    • Box400
      • May 2012
      • 16
      Thanks for the dental pick suggestion. It's a good idea.
      I would try to turn the lock with the broken part in there, but I think that's the root cause of my problem: the cylinder didn't turn at all even with a whole key.
      Was there a valet key on the '88s? I'm thinking I just have a copy of a valet key and not a proper owner key.
      Also, can someone tell me whether the trunk is locked when key slot is horizontal or vertical (or neither)?
      • jw 325ic
        • Sep 2006
        • 1360
        If its vertical to the right its locked and wont unlock w/ the doors. If its locked and horizontal it will unlock with the doors.
        • Northern
          I like cupcakes & sh!tboxes
          • 5284
          When this happened to me, I managed to pull it out with a pick and some small needle nose pliers... one of those surgeon's plier clamp things would be even better.
          Originally posted by priapism
          Originally posted by shameson
