Here's the deal. If you figure out how to get my car running, you get $25 via paypal.
I'm an honest person, and I'm not going to cheat anyone out of their deserved reward. But, if I figure out the problem before anyone has the chance to post it on this thread, you lose.
I have an older thread(http://www.r3vlimited.com/board/show...=1#post3237251) with this same problem, but not many people seem to have any interest in helping me.. :dot:
My problem:
So my e30 is literally 95% put back together. It's a 1990 325i sedan with the a 1987 325i motor. Did a 5 speed conversion during the engine swap as well. Wires under the shifter are all connected correctly and the c143 under the dash is also disconnected. All I have to do is figure out why it's not getting a spark and put the interior panels back together.
The main problem I have right now, is the no spark issue. Giving the car enough juice, I try and turn it over, but it doesn't get a spark. But as SOON as the engine stops turning(when we turn ignition off), there is a spark.
I already changed out the coil, the cap and rotor, and the crank position sensor. Does anyone have any ideas?
Thanks in advance.
EDIT: When I got the car, it had a bad motor, with a great condition wire harness. I then got the 87 i motor and used the harness off of the bad motor.
My problem:
Thanks in advance.
