$8 Smoke Test, with pics (and also high idle issues)
  • Timp
    • Jun 2011
    • 126
    Good news. It appears that plugging and unplugging the TPS (for the purpose of running a test) has fixed my idling issues for the most part. It now idles at ~900. My guess is the connection was corroded perhaps. This seems like it was too simple of a fix.
    Newb to all the things.
    • Aleksey
      • Feb 2011
      • 336
      The part of a proper smoke test is intake pressure. If you want to find obvious leaks you can just take a hit of hookah and pump intake with the smoke but this will not find any of the smaller leaks (injectors, etc) because pressure is too low.
      I always use carb cleaner trick and it works really well on E30/E34, etc since everything is out there in the open.
      Founder @ Maintenr. Take control of your vehicle maintenance.
